C5 Hdi Undershield
jmd
C5 Hdi Undershield
Unread post by jmd »
How important is this under-shield, it is such a nuisance when carrying out an oil change. I try to keep things as the manufactured intended, but my son just rang me to say that his under-shield has partly fallen down on the road. Wondering if I should remove it all together. Has anybody decided not to replace theirs. I have driven my Xantia without it's undershield and had no adverse effects. Wondering about the C5
x 1938
Unread post by Paul-R »
I don't know about the Xantia but on the C5 the undertray and the other plastic panels underneath tie together and give each other strength.
There is a post somewhere here from someone who lost part of one of his plastich wheelarch liners as a result.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
My advice would be to keep it. When I had my Xantia I left the undertray off over winter after doing an oil change. By the spring, one wheel arch liner had flapped about so much that it was broken. The undertray keeps everything in it's place.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Citroenmad
x 110
Unread post by Citroenmad »
On the C5 the undertray holds the wheel arch liners in place and secure. Without it fitted the wheel arch liners usually touch the wheel and break or just come off, never to be seen again. Cars must have wheel arch liners.
Its there for other reasons, engine cooling, protectiong, etc. So its best to have it there.
It is a fiddle to remove on the C5, and i often hear a pin or two ping down the underside of the car when ive had mine off. So mine is now mostly screwed on now.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
cachaciero
x 9
Unread post by cachaciero »
Simple solution, get a vacuum oil extractor pipe goes down dipstick hole no need to remove under tray :-)
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
Citroenmad
x 110
cachaciero wrote:Simple solution, get a vacuum oil extractor pipe goes down dipstick hole no need to remove under tray :-)
cachaciero
I have one, but the oil filter on the 8v HDi is a metal canister type on the fron of the engine. Removing that without the undertray removed would make a nice mess. So i never use it on the C5.
03 Seat Arosa 1.0S
cachaciero
x 9
cachaciero
Do you mean a bowl into which a filter element is placed? didn't think that kind of filter had been fitted on any car since Methuselah :-)
Mind I reckon a bit of oil flowing back from the engine and painting the underside is a good way of keeping the metal moth at bay.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
x 1938
Maybe the 2.2 has a different filter and position to the 2.0 but I know that when I take the filter off my 2.0 I need the undertray off so that I can make sure I wipe as much oil as possible off the engine block, A/C compressor and pipes.
jmd
Thanks to everyone for the advice. It seems that I had better source a new under-tray. Thanks cachaciero, but I have used the vacuum tube on 3 cars. On the Xantia & C5 I found at least 1.5 to 2 Pts of oil were left behind in the sump. On our Saxo (only) the oil has been always totally & completely drained, using the extractor. So naturally I have reservations about vacuum extractors.
x 5672
Paul-R wrote:I don't know about the Xantia but on the C5 the undertray and the other plastic panels underneath tie together and give each other strength.
That was mine - the wheel arch liner exploded at 90mph :(
Still haven't done anything about it and the undertray is still in the garden. Doesn't appear to be sprouting a new wheel arch liner though.
Mine was held on with zip-ties.
Clogzz
x 40
Unread post by Clogzz »
Previous undertray topic:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=30697
A square can be cut out of the under shield to reach the sump plug.
On the 4-cylinder petrol car, the oil filter can be changed from the top, with newspaper on the shield to catch the spill.
JohnD
(Donor 2022)
x 72
jmd wrote: So naturally I have reservations about vacuum extractors.
And so do Citroen - especially on 1.6 engines.
Citroën sent this to dealers:-
OIL CHANGE PROCEDURE
It is necessary to follow a specific oil change procedure on all DV6 and DV6U engines so as to ensure that no used oil remains to mix with the new oil.
The following method must be used:
• The engine oil temperature must be at least 50°C :
- the engine oil temperature is considered to be at 50°C when the water temperature indicator is between 80°C and 90°C or the cooling fan has cut in
• ensure that the vehicle is level (side to side and fore and aft)
• remove the oil filter to allow the circuit to drain completely
• remove the oil filler cap and the dipstick
• remove the drain plug
• allow the oil to drain by gravity for at least 10 minutes (DO NOT USE SUCTION METHODS)
• fit a new oil filter
• refit the drain plug with a new sealing washer
• fill the engine with quantity of oil recommended for the engine
• refit the oil filler cap and the dipstick
• run the engine at idle until the oil pressure warning lamp goes out (about 1 minute)
• wait 5 minutes
• check the oil level using the dipstick: the level should be as close as possible to, but not exceeding the maximum mark (1) so as to be between (1) and (3)
These instructions were published to combat the alarming failure rate of turbos.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 1938
myglaren wrote:That was mine - the wheel arch liner exploded at 90mph
When driving in Germany no doubt. :roll:
x 5672
Naturally - that's why my display is in German :twisted:
Citroenmad
x 110
I think the 2.2s have the paper filter element which is replaced, where as the 2.0s have the old style metal cylinder filter. 16v HDis have the newer style paper filter.
03 Seat Arosa 1.0S
