C5 Rear Calipers and Disks CHECK YOURS!!!!
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi all...
Just a information point here rather then help wanted...
Called to rear Pad worn out on a C5, 2002 model HDi.. Ok no problem.. got the pads.. all set.
Rear wheel off on Nearside, and to my horror, it was extreamilly noticable the calliper was at a 15 deg angle to the disk!!! I thought this would have only been a Xantia problem, but appears worse on the C5... not only that, it was that bad it had dug in and worn the disk on the inner side, so not viewable through the alloy!
I ONLY JUST managed to remove the bolts without breaking them, cleaned the face up, but had to reit one old pad on the inner side and a new pad on the outer, while I ordered disks...
Thats the next shock... bigger disk, bigger price! I was looking at around £70 for a PAIR :o
Up shot, hopefully get them fitted for customer this weekend, and damm hope the drivers (O/S) side caliper is not as bad as the passenger (N/S) side.
So, C5 owners, it appears they suffer just as badly!! Ive not seen a Xantia caliper wear a disk, so CHECK YOURS on the inside and outside, NOT just by looking through the disk.
Paul
A very sad...
1994 XM 2.1 d auto
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Wouldn't you have thought Citroen would have done something about the problem? It's been around since BX days.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
spider
x 77
Unread post by spider »
Do C5 rear discs come with the bearing ?
I think they changed Peugeot's (307's) around 06 or so, which would I guess increased the price of rear discs quite a lot.
Andy.
x 94
Unread post by citronut »
i had extream problems on a C5 which i had in to fit rear arm bearing on both sides,
the N/S bolts were so stuck in the calliper even after they had finnaly unscrewd from the arm, i ended up buying new bolts and drifting the old ones out of the calliper very tight all the way out), i have heard it said they are lock tighted down there shancks through the calliper body,
on unscrewing them the moved an 1/8th of a turn at a time with loud creaking all the way out of there threads in the arm,
the arm bearings were very easy,
my local dealers parts manager told me there fitters dont bother trying, they just lop off the old calliper's and bolts and fit everything new, as at there hourly rate it works out cheaper
regards malcolm
x 1061
Unread post by wheeler »
spider wrote:Do C5 rear discs come with the bearing ?
The C5 ones don't have the bearings in them, just plain discs.
citroenxm
Fallen Hero
x 70
Xantia Rear Disks are JUST disks too!
Its the rear hub which is bearing enclosed too...
The rear C5 disks are about the size of Xantia TD Front disks!!!!
Malcolm, I DID have trouble with the bolts sticking in the calliper, however, after a clean up, and all looking ok, I reused it all...
A very sad...
1994 XM 2.1 d auto
Duracell
Unread post by Duracell »
My experience is that the this problem is worse on the C5 than either the Xantia or BX's - Both our C5's had to be done at 4 years old and about 60,000 miles - I've never had that problem on a BX or Xantia anywhere near that early. I managed to unscrew the bolts out of the caliper with an air spanner and then drilled out the remaining locktite - anybody have any idea why Citroen think its nessecary to glue the bolts in?
cachaciero
x 9
Unread post by cachaciero »
Duracell wrote:My experience is that the this problem is worse on the C5 than either the Xantia or BX's - Both our C5's had to be done at 4 years old and about 60,000 miles - I've never had that problem on a BX or Xantia anywhere near that early. I managed to unscrew the bolts out of the caliper with an air spanner and then drilled out the remaining locktite - anybody have any idea why Citroën think its nessecary to glue the bolts in?
Think about it ,place caliper on arm pick up bolt, dip threaded end in loctite feed bolt through caliper and tighten ergo thread lock all the way down the bolt easy :-) Of course one could apply loctite to the female end but that is a lot more time consuming and we all know time is money :-)
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
Duracell
Its more sinister than that - the correct proceedure is to insert and tighten bolt and then inject the correct loktite product (can't remember which one it is) through an access hole provided in the caliper - the idea is to fill any free space between the unthreaded part of the bolt and the caliper and 'glue' it in. This method of fixing the rear caliper bolts is not found on all C5's - unfortunatley it applied to both of mine
x 94
i found no sign's of locktight on the threaded part of any of the bolts i removed, it was as Duracell says thick wadge all the way up the shanck but non on the thread,
regards malcolm
Clogzz
x 40
Unread post by Clogzz »
Removing bolts with a torch:
:evil:
Image Image
frenchcarnut
Unread post by frenchcarnut »
Duracell wrote:Both our C5's had to be done at 4 years old
Exactly the same as mine but at a loss less mileage. Pretty infuriating for a relatively new and serviced car at the time.
04 C5 2.0 Auto HDi VTR
JohnD
(Donor 2022)
x 72
Duracell wrote: problem is worse on the C5 than either the Xantia or BX's - Both our C5's had to be done at 4 years old
Just the opposite for me. The Xantia needing doing at an early age but so far no sign on the C5 - and coming up for 6.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 1955
Unread post by Paul-R »
Flipping 'eck Clogzz - that's a clean floor and tools you have there.
dnsey
x 19
Unread post by dnsey »
At 10 years old, mine's just about showing the fisrt signs on the o/s caliper only (must get it done before it gets too bad).
I understand that Citroen's recommended procedure is to apply gasket compound to the mating faces on assembly to prevent the bimetallic corrosion. Perhaps the difference of severity between our cars depends on how well this was done in the factory.
