QUARTZ ENERGY 9000 (5W40) good enough for a 2.0 HDI?
citroDane
Unread post by citroDane »
Hi guys,
I've seen this oil on sale but was wondering if it is good enough for my 99 Xantia that has a 2.0 HDI engine. The car has a catalytic converter and my only concern is -looking around the web- a lot of people say the kind of oil good enough for a car with diesel particulate filter must be ACEA C-rated and this one doesn't seem to have it.
I've looked at Total's website (they only spec the 0W30 but that's only grade?) and there's only an ACEA 2004 : A3 / B4 rating, +API : SL/CF, MB 229.5 and BMW Longlife 01 compliance statement. Here's the link:
http://www.lubricants.total.com/lub/lub ... F3004DB954&
They also say it's 100% synthetic and "can be used for all Gasoline and Diesel engines, especially for the most recent engines."
None of this indicates to me, that it cannot be used in a modern diesel engine with DPF. But why is it missing the ACEA's C-rating which obviously has been created for people with DPF as a green light to use it?
So what say you? Good, no good? Much appreciated.
Cheers,
Gabriel
99 Xantia, 2.0 HDI
TKM 215
x 1918
Unread post by Paul-R »
I think I've found the spec sheet for the grade you want but it doesn't seem to be any better.
http://www.lubadmin.com/upload/produit/ ... _1/162.pdf
x 1479
That's perfect for your engine - in fact, the Citroen recommended oil AFAIK :lol: Only cars with particulate filters require a better (low ash) oil - yours only has a cat converter which doesn't really care.
steelcityuk
Unread post by steelcityuk »
That's what I used in both the Xantia and C5 HDi.
Steve.
not applicable
citroDane
Thanks guys.
For whatever reason I can't open that link. I'll try again later.
But if you say the cat convertor is not as picky as the DPF (I actually thought the cat convertor was a type of DPF...passive) and Citroen recommends this oil, then I'm going!! :D
99 Xantia, 2.0 HDI
TKM 215
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
That oil is what Citroen recommend for HDi's as listed in the handbook.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
RKM
Unread post by RKM »
I would have thought that the oil would be fine. You car has a cat and not a DPF.
DPFs need oil with low levels of certain additves (I forget what they are now) so that, when the engine burns the oil, it does not clog the DPF prematurely.
R
imperial21
Unread post by imperial21 »
i am running elf 5w40 fully synthetic in my HDI xantia. all ok so far !!
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
citroDane
Thanks guys. I'm gonna buy the oil tomorrow. :)
/G
99 Xantia, 2.0 HDI
TKM 215
