406 radio
markja55
406 radio
Unread post by markja55 »
hi, i have a 406 mk2 51 plate. recently the radio has been playing up and losing the signal. scrolling through the wavelenths. (fm1,2,3 am back to fm1 ) did the trick. it now doesn't find any ststions even on manual tune. cd player is ok. tried a wire in place of aerial but no joy. amyone know what bit of the stereo causes this?
cheers mark.(man with a soldering iron at the ready.) not trained on radios so can't fault hunt it.
skyclad
Unread post by skyclad »
If its not the aerial then there's not much you can do. The reciever parts in modern radio's are basically one module, unrepairable for the most part.
Try connecting a complete (cheap) car aerial directly from the unit, hang it out of the car window, and see if that works.
Pug 406L 1997
Transit Campervan 1990
toh
x 5
Unread post by toh »
hi,
Have you try to pull it out to notice the ant plug behind the radio?
by the way, Picture can say clear.
LOVE is All AROUND.
