Best way to tune a 205 xs?
[email protected]
Hey guys does anyone know the best way to tune a 205 xs? Iv been considering an engine change maybe GTI? How much work would this involve thanks
spider
- x 77
Is it the (rarer) twin carb XS ?, if they are set up properly they do go very well anyway, although you will need a decent garage to properly setup a pair of carbs, the 'art' of doing this by ear seems to be fading now (Jim, if you read this I bet you know how to listen to balance a pair)
A simpler change would be to replace the 1.4 TU engine with the 1.6 TU unit really. The gearbox can stay. The brakes I'm not too sure as the driveshafts / hubs are different. Possibly the 1.6 auto brakes would offer improvement.
You could use the XU (the GTi) units, either carb or injection (carb will be a hell of a lot easier as you have that already) but if you did this you will need a gearbox / driveshafts / hubs and front brakes at least.
Andy.
KP
- x 27
[email protected]
spider
- x 77
They did not do a carb GTi
I was thinking of simplicity that's all.
The 1.6 TU is the 306 1.6 unit (looks like the 1.4 you have, more or less) it is a cast block instead of liner'ed though (probably better) , that's just the 'easy' upgrade, and should generate a bit more power. Not a huge amount, but a bit more.
Depends what you plan really. The 1.6 XU (the GTi unit or any 1.6XU really, 405 maybe?) or possibly the 1.9 unit along with a pair of carbs (or a single one) will provide plenty of power.
You could always use one of the XU8J4 / XU10J4 units from a 406, you will need a gearbox if you do this obviously.
Another idea: The XU10J2 unit (the rare-ish 2.0 8v turbo engine) into a 205. It is a tight squeeze though from what I understand.
Andy.
siraff
spider
- x 77
Oldpug
- x 93
spider
- x 77
Sort of, although you can fit a carb + manifold to the 1.6 TU unit and do away with the injection system, which is what I meant. You only need to comply with the age of the vehicle not the age of the engineOldpug wrote:The 306 1.6 Tu is injection so you will have to replace the ECU and the whole engine bay to dash wireing harness and fit an exhaust system with a catalyst plus lots of "bits & bobs".Is it worth the hassle?? Like the man said sell it and get a GTI.
Andy.
