berlingo horn and airbag fault! Com2000
ifred
Unread post by ifred »
Hi Guys
Sometime ago my airbag light came on when all through the contact cleaning
tricks and tips fix it for a while then it can back fixed it again then it came back intermittent then became a permanent fault
Now I have a none working horn arggh!!!
Taken the airbag of taken steering wheel off clean the Com 2000 rotary connector no joy. I know a new Com 2000 is a lot of pennies for a common weakness of the component.So any good suggestion ?
Also I was thinking I might put the horn on a press button switch on the fixed part of the steering wheel cowling. Can anyone give me an idea how and where to pick up a live feed from?
Any ideas will be appreciated
By the way its a 1.9D 2003 berlingo in Spain :-)
spares are very expensive here as are also the breakers
Cheers
frenchcarnut
Re: berlingo horn and airbag fault! Com2000
Unread post by frenchcarnut »
ifred wrote:Hi Guys
Cheers
Hopefully someone here will be able to help as there are a lot of technically able and helpful individuals on here, but have you also tried the new Berlingo forum?
http://www.berlingoforum.co.uk
04 C5 2.0 Auto HDi VTR
ifred
Any help on this guys
Check the Berlingo website its still quite new Will register and post a question
Cheers Chris
demag
x 102
Unread post by demag »
There is a "how to" article on there about the com 2000.
Dave
ifred
Yes there is a how to replace the comm 2000 unit from the aussiefrog original. But I need a little more in depth. this stops just where I need the help.
was hoping someone had dismantled the circuit board connection to the ribbon in the rotary connector. This is where I think the fault lies?
If I could take a feed of here for example it might work without an external push switch.
The original design here is really very poor
Regards
Fred
ifred
Any help here the Berlingo forum is still a little young and short of posters :(
