HELP oil leak
monkfish
HELP oil leak
Unread post by monkfish »
hi guys i thought i had stoped my smaal oil leak on my 2.2 hdi c5 stoped for a couple of days but its back i think its the oil feed pipe for the turbo the one with the banjo joint so how hard ie this to change and if in a gagrage how much many thanks for any help :oops:
c5 2.2 hdi sx
xantia 1.8 sx
bx 1.9 gti 8v
HDI
x 7
Unread post by HDI »
Depends where it's leaking from, if it's from the joint between the hose and fitting then the hose will need changing, if it's the banjo connection itself then it will need the sealing washers replacing.
Shouldn't take any more than an hour in a garage + parts.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
