how do i change bulb on speedo cluster citroen c5 mark 1???
gazzas c5
how do i get access to the c5 mark 1 speedo cluster as i want to get access to the rear of the speedo cluster,what does it involve for me to get into it?cheers folks!!
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
- x 1061
It's really easy to get the instrument panel out, if you look at the bottom of the panel you will see a dot in the plastic at either side. Where each dot is use a plastic lever (or something similar that wont damage the dash) & prise the dash up & it will pop out. No screws or anything.
Only problem it there are no replacable bulbs only LED's soldered onto the board.
