xantia heater control
imperial21
Unread post by imperial21 »
Hi All
I thought the switch is supposed to select about 5 different speeds ? i put my fan on Auto mode it starts off slow then goes full speed, when going the manual way i have to be very careful to get slower speeds :roll: is my heater resistor on its way out ???
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
x 1240
Unread post by Peter.N. »
If its got 'auto' on it I would suspect its the type with a transistor regulator on the blower motor, the transistors go faulty and cause all sorts of strange things.
x 8289
In auto mode, which is the normal mode, the fan speed should vary automatically to keep the cabin temperature constant. Generally it spins over fairly slowly.
In practice this works well in all modes except demist where the fan does tend to run fast when the weather and car is cold.
I have always found the manual speed selection a bit sensitive. All of mine have tended to give three slowish speeds and then full-tilt hurricane-speed at the top end with little really in between.
Remember also that in demist mode on a MK2, the aircon will automatically fire up if the incoming air is not too cold. That'll have an effect on blower speed.
x 1480
Sounds about right Jim....mine does random things in Auto so sits in position 3 to the right most of the time. This gives a barely audible fan speed. One more increases it to audible, and Max results in the gale / deafening status!!
imperial21
Hi
you have put my mind at rest it sounds like mine works about as good as they get !!! :P
