£100 quid Picassssoooooo update
x 94
Unread post by citronut »
this is an 02 1.8 16V
replacement lump all in and running seems ok,
but in the procces of running it in and out of my workshop over the last couple of weekends, it has sooted all four plugs up, i noticed today on startting her up she was not quite happy,
pluged the Dis Lexia in and ran it in paramiter check mode this is what it says
with coolant tem at 96c
up stream sensor voltage constantly flitting from
0.839 to 0.098
down stream sensor voltage startted of simmilar to above then settled to
0.117 to0.098
coil charge time's
1 and 4 kept changeing from 1.6ms to 2.5ms
were 2 and 3 stayed at 2.5ms
i fitted the other seat of spark plugs and cleard fault codes, and ran the engine up again,
checked fault codes again and it says
permanent fault + APC 0-3n circuit
is any of this relavant or am i more confused than i started as
regards malcolm
ps.
i did use all the sensors and device's from the old engine
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Malcolm,
Do you have the fault code numbers? With the numbers the fault can be identified in the Citroen manual which often gives a cause/remedy.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 94
sorry Richard but were do i find them or did i miss them (probably :oops: )
regards malcolm
x 94
i still cant find the actual fault code's Richard,
in the passed when i have run a globle test with my DIS LEXIA, if i select any one area it says there are faults found, then it would alow me to select each fault, but on this Picasso i cant open any of the faults listed,
permanent fault
EOBD or ENGINE ECU
permanent fault
no comunicatiom with A/C
permanent fault
+APC open circuit
what is the APC
regards malcolm
