406 hdi 110 clutch conversion
Wil
Unread post by Wil »
Hello, I have a 2002 2.0 hdi 110 with what sounds like a noisy thrust bearing as there is a squealing noise when depressing the clutch pedal.
Will a solid flywheel and clutch off a '98 406 2.1 td fit the car and bellhousing which is a pull release same as the hdi 110?
I would prefer to do away with the dual mass flywheel if I am replacing the clutch. I have a 2.1 flywheel and clutch from a car I bought for spares. Although I would fit new plates and thrust bearing.
Anyone done this type of conversion?
flying clutchman
x 3
Unread post by flying clutchman »
If you wish to fit a solid flywheel it's best to buy a valeo conversion kit. This is made with a clutch which they claim has extra 'give' in it to replicate the damping effects of a DMF. I've fitted quite a few of these to various vehicles with good results. The kit contains all clutch parts +flywheel and bolts and works out pretty reasonable. Eurocar spares normally stock these.
dieselnutjob
Unread post by dieselnutjob »
My 806 HDI 110 has a Valeo four part clutch conversion kit and it's great.
The engine is very slightly louder on full acceleration but otherwise you don't notice any difference.
Wil
Thanks for al your information . But what I really wanted to know is ' would the 406 2.1 flywheel fit onto my 2.0 hdi?'
x 1487
Citroen list a different part number for the 2.1 TD flywheel vs the 2.0 HDi 110 (which uses a solid flywheel in the Xantia) - but the same clutch. So i might fit - there's probably only one way to find out!
