Hi
Has anybody ever had a problem with the throttle sticking on a C5 HDI. Twice now when I have accelerated hard the cars revs have shot up and stuck at that level. Since the car is automatic the only solution is to knock it into neutral - the revs die down to normal after about 30 seconds. Any ideas?
TIA
C5 Sticking Throttle
- x 1044
Delta Wizard
Sticking Throttle
Hi
The pedal seems to be clear of any obstruction - I have checked it by hand and using my foot. there is a thick wire that is fastened to the shaft of the pedal - I did wonder whether this could catch on the mounting plate bolts.
Somebody else has suggested that the the throttle potentiometer might be to blame?
TIA
TIA
spider
- x 77
Did you confirm the engine oil level is NOT overfull ?
Although when they run away like that they tend to make an awful noise, and a lot of smoke (perhaps the stronger emission control systems can contain that though)
Check on level ground after the engine has been stopped for at least a few minutes.
Andy.
