Testing Turbo
ataxidriver64
Testing Turbo
Unread post by ataxidriver64 »
Hi is there any way to test the turbo whilst it is still on the car? citroen C5 2.2 hdi auto.
JamesQB
x 5
Unread post by JamesQB »
You can take the intake pipe off it and spin the compressor to ensure it hasn't seized. Should spin freely.
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
x 1240
Unread post by Peter.N. »
Disconnect the air intake pipe from the manifold, when you rev the engine you should have a strong draught from the pipe.
KevMayer
Unread post by KevMayer »
Get a turbo boost gauge and temporarily plumb it into the small pipework on top of the intercooler.
Use a long silicone pipe and mount the gauge in the car with the window slightly open to let the pipe through.
On the 2.2 Hdi you should get 1.1 bar at 2000 rpm and 1.2 bar at 3000 rpm.
Cheers, Kev
ataxidriver64
it doesnt rev much now, would that be a fault?
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Sounds like shes slipped into Limp mode...
you can be guessing all day what could be wrong, she needsto be plugged into a Lexia diagnostic machine to have the faults read...
Paul
A very sad...
1994 XM 2.1 d auto
ataxidriver64
turbo
Well turbo was broken, now a new one fitted.
Bearings had given up the ghost.
Deanxm
x 87
Unread post by Deanxm »
Sorry to hear your having trouble
Is that the new bearings have given up? if so there is an oil feed issue, the turbo wasnt primed before fitting or it was not ballanced and broke through the oil film the main shaft is suspended on.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
KevMayer
On my 2.2 Hdi, I've just had a boost gauge connected as above and at 70 mph in 4th gear up a long hill on a dual carriageway I got just over 1.1 bar. Peaking very briefly at approx 1.2 bar.
Cheers, Kev
