My wife has a 2001 multispace, the drivers seat is shot and i was wondering does anyone know of a seat from a different car that can be fitted-preferably with height adjustment?
thanks in advance
Berlingo Multispace Front Seats
spider
- x 77
The obvious other choice is the Partner Combi (as its the same vehicle) if you can find one.
Failing that a Berlingo or Partner van will hopefully provide a suitable seat.
Its probably possible to swap them side to side if you can only find a good passenger seat (do not do this if you have side air bags) , although you may have to do what I did on my 205 and actually then strip the seats quite a lot to swap the frames over as these are handed.
I'd personally just look around for a seat from another Berlingo / Partner, there should be plenty around. The problem with getting say a ZX etc seat to fit is not only the height its lining the runners / frame up too.
Andy.
nickmurphy
spider
- x 77
I'm not sure what is different off hand, it has been about 5 years since I last saw one
I'd assume the mutispace ones are swivel ? (or perhaps have extra 'features' rather than being physically different (although the bases might be different they could be swapped)
Cannot really say much more as I am not sure.
, hopefully someone who is more familiar will be able to add more information to help you.
Andy.
