Berlingo Steering Wheel Question
sledge
Unread post by sledge »
Hi all.
I have a 2000 model year V reg berlingo 1.9D.
I would like to change the steering wheel, which does have an airbag.
Would a steering wheel from a pug 206 LX fit my van ok?
Thanks in advance for any advice.
Nige
spider
x 77
Unread post by spider »
It 'might' actually fit, although as the Berlingo is the same as the Partner (more or less) and that is based on the 306, in theory a ZX wheel should fit.
Caution: Your airbag is probably not safe to connect back up if you do this, due to changes in the airbag ECU. As far as I am aware, each airbag type is designed for that ECU, with respect to trigger pulse / time and other factors.
If you did change wheels, (speaking as if it was me wanting to change wheels on mine) I would not be connecting the airbag back up.
Sorry that's not a lot of help, but I am not aware of the intricacies of differing airbag modules / ECU's and it could be potentially dangerous to 'mix and match'
Andy.
