Xantia Comfort?
XantiaDaveEire
x 4
Xantia Comfort?
Unread post by XantiaDaveEire »
Should a well maintained Xantia feel better on good roads as oppose to bad roads?
On smooth roads i cant feel a thing,but on slightly uneven roads i feel every damn thing
And this is after changing the front 2 spheres and the accumulator :roll:
New clean healthy lhm...new spheres..correct tyre pressures
I just dont feel that im getting the quality of ride i should be
:cry:
Any advice or opinions welcome!
Dave
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k #-o
Dommo
x 20
Unread post by Dommo »
Is the car a hydractive car? (VSX/Exclusive)
If so the centre suspension sphere is the 'comfort' one, without it it's effectively running in sport mode all the time.
x 8386
Is this a Hydractive one Dave?
XantiaDaveEire
x 4
Nope sorry forgot to mention it..
She is Non-Hydractive
Dommo
x 20
And it's definately running non-hydractive spheres?
The damper hole on hydractive corner spheres is much smaller than on non hydractive spheres
red_dwarfers
x 58
Unread post by red_dwarfers »
I find that mine feels better on smooth undulations rather than the rutted potholed roads. On the rutted roads round here you can feel every damn thing but its still noticeably better than other cars I've been chauffeured around in.
Kev
'19 C4 Cactus 130 Flair
XantiaDaveEire
x 4
Dommo wrote:And it's definately running non-hydractive spheres?
Definately the correct spheres
They are 55 bar in the front
And 30 in the rear
Iv just compared the damper holes between a Hydractive and Non-hydractive front sphere,and to me there isnt any differeance what so ever :evil:
Dave
Citroenmad
x 110
Unread post by Citroenmad »
There should be a slight difference in the damper holes between the two.
Is the ride height correct?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
XantiaDaveEire
x 4
The ride height is perfect :lol:
Il just have to see how i get on when i do the rears and see if that makes any differance,although to me 30 bar seems a little low?
jgra1
(Donor 2021)
x 37
Unread post by jgra1 »
hmmm... agree with Kev :twisted:
I think that you get so used to the good bits of the ride, that smaller sudden ruts show up more..
drive my coupe and you wont believe the xant afterwards :D
x 8386
jgra1 wrote: drive my coupe and you wont believe the xant afterwards :D
Indeed so :wink:
We all get so used to the excellent ride that after a while it seems to be not quite so good as it was. We get complacent.
Only one solution..
Go for a drive in a non-hydraulic car and then do the same trip in a Xantia..
All will then be revealed :D
Toby_HDi
x 3
Unread post by Toby_HDi »
jgra1 wrote:drive my coupe and you wont believe the xant afterwards :D
You're Coupé felt comfortable compared to mine!
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
robert_e_smart
x 14
Unread post by robert_e_smart »
Only one solution..
Hear, hear.
Get someone in a VAG group product to take you for a drive, and you'll appreciate the Xantia. Its a bit like the rule of driving a slow car to appreciate a fast one.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Dave, I would get an experienced Citroën mechanic to look at the front lower balljoints and bushes, and anti-roll bar in entirety.
I also believe the strut top rubber hardens with age, even if the Series II cars are a "failsafe" design. Similar suspicions exist (within me) about hardening of subframe bushes.
Based on my own observations the other day, I'd also check the lubricity of rear strut pistons at both ends.
Citroenmad
x 110
Apparently S2 Xantias strut tops fail like S1 cars, i was looking at some at a CCC event and they were definitely past their best ...
You can increase the pressure in the sphere slightly to give a better ride with sphere regassing gear. This is the best way of improving ride quality (so long as every thing else is right with the suspension of course), playing with the damping hole just effects or removes the damping and the ride is awful, very uncontrolled - this is what comfort spheres are.
Though it would seem very few people now have regassing equipment due to the cheapness of after market spheres. Going from 30bar to 35ish would improve the ride more than you might think.
Some people also play around fitting spheres from different models, which can also improve the ride depending on the pressure and damper hole.
03 Seat Arosa 1.0S
