I have looked through and seen so many questions on cambelts for the TD engines, but must be limited, or missed the petrol engined threads
Basically, I am wondering whats needed, tool wise for this, does it need specialist tools?
Also, is its a harder than normal job? the garage the car sales place use has refused the job as he cant stand working on these cars, which is strange for a garage but hey, his loss...My family friend mechanic believes he may need specialised tools so not sure if he can do it
Is it really that hard to do on these cars???
So, who has done a petrol engined cambelt that can give me an idea of what the cost of parts would be roughly?
thanks
cambelt (petrol engine)
Pompey_Dave
Metallic Red 1999 Mk2 Xantia, 1.8Lx
jgra1
- (Donor 2021)
- x 36
Dave, i dont think I have done one on a 1.8 Xant, but i cant see it's any harder or needs any major bits over a Deisel one.. should be a straightforward job really
others will know more..
I did a 1.8 twin cam escort and the V6, neither horrendous.. its access that makes the job hard, access to the belts and getting everything out of the way first..
spider
- x 77
I did some on 406's 1.8 / 2.0 but we are going back about 10 years ago.
From memory: you need a pin or large bolt to insert into the crank pulley before removing it so its in the correct place, there's a casting on the block (like a U shaped thing)
I cannot remember if the cams have locking pins too, I think so.
One thing I do remember, if you take the pulley off and its not lined up , you may need a new pulley as its not unknown for them to separate, its not possible easily to do a belt (as you cannot find TDC) if this is the case.
Andy.
Pompey_Dave
- x 94
if its a twin cam i think you lock the cam,s at the gearbox end, remove the cam covers then line up the cam's and there is a slot across the end of both, which you place a length of flat steel bar about a 1/4 of an inch thick,
and peg the crank as Andy say's i think its an 8 or 10mm bolt used for this,
so not anything to special in the tool department,
regards malcolm
regards malcolm
spider
- x 77
I think that's for the Zetec engines ?citronut wrote:if its a twin cam i think you lock the cam,s at the gearbox end, remove the cam covers then line up the cam's and there is a slot across the end of both, which you place a length of flat steel bar about a 1/4 of an inch thick,
regards malcolm
Andy.
addo
- Sara Watson's Stalker
- x 95
Warning! Possibly inaccurate information... Based on observation and foggy memories of past observation.
The cams may have five of six millimetre pin (locating) holes through the first bearing cap past their pulley.
Mi16s also have a frontal pin; you don't need to remove the timing covers.
Later 16V motors have the crank pinning hole located off the damper outer ring, so you either need a "definitely, treely ruly known good" damper or buy a newie.
Toby_HDi
- x 3
The Turbo CT has this too. Thanks to a heads up from Jim, a quick trip to the scrappy saw a solid one procured from a 205.addo wrote:Later 16V motors have the crank pinning hole located off the damper outer ring, so you either need a "definitely, treely ruly known good" damper or buy a newie.
Dave, judging by your name I'm guessing you in Portsmouth. You're welcome to borrow the solid pulley I have and if you want to have a go at the belt itself I'm willing to help. I've done two now, a HDi and a V6. The V6 with its adjustable pulleys are about as difficult as it gets. After doing a couple I find the stigma of a cambelt job has all but disappeared, you have to be careful and thorough yes, but there isn't much to it in the end.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
jgra1
- (Donor 2021)
- x 36
- x 94
Pompey_Dave
Thankyou toby, but as for me doing it, I wouldnt have a clue so I have to pay someone to either do it for me, or help me and show me the ropes, I would probably kill my car haha!
I can do alot of different work to cars as I have been taught many things over the years, my old man used to be a mechanic but he doesnt do anything to cars anymore, and he keeps telling me he is too old to do it now too haha!
As for the engine, my car is the mk2 1800 16v
If someone wants to help me and knows what they are doing then im more than happy to pay for peoples time, just depends how far away from portsmouth people are
jgra1
- (Donor 2021)
- x 36
Pompey_Dave
MikeT
- x 232
Dave, take Toby's offer, buy the parts and swot up on the procedure from a Haynes manual. Chances are, you'll not only find you can do it yourself, but the rewards of DIY are more than worth it.
I'd be happy to help too as I enjoy new learning experiences and as Toby mentioned, if we can do a V6, a straight four should be a walk in the park. Go on, accept the challenge.
citroenxm
- Fallen Hero
- x 70
