Hi, I have a 2004 Clio. (With air con)
The blower (whether hot or cold, makes no diff) only works sometimes. Doesn't matter if it's set on auto or manual.
Can be driving along and suddenly it just comes on but usually its not working.
Would the problem be the heater resistor, heater motor or something else?
I did a search but suprisingly havn't found a topic on this.
Any help would be really appreciated.
Heater Blower only working intermittently
gp92
Re: Heater Blower only working intermittently
You should check the heater fan motor resistor and wires/connectors on the blower assembly. The videos below may help you, if you are planning to do it yourself.
Removing the Heater Fan Motor Assembly: http://www.youtube.com/watch?v=PgZE0eM65iY
Heater Fan Motor Disassembly: http://www.youtube.com/watch?v=krbIlqbXQbo
Are Chinese car makers now coming of age? http://www.youtube.com/watch?v=ohMNhhwlydI
