Mk1 & Mk2 Xantia doors
A1d1e
Unread post by A1d1e »
Just totalled the passenger front door on my Xantia. Can anyone tell me if there is any difference between hatch back doors for both models?
Been offered a door from a mk1 by a scrapyard but don't want to waste time or money, got to have it sprayed and fitted!!!!
andmcit
x 30
Unread post by andmcit »
Yes they're different for the back doors but fine on the front!
Which colour is it - paint code ESYCR etc on firewall bulkhead.
Where are you located?
Andrew
x 1486
Unread post by xantia_v6 »
Just for clarity, are you asking if hatchback and estate doors are the same? or if hatchback doors changed between Mk1 & 2?
I put a Mk2 rear door on my Mk1 V6, and other than having to change over the window motor assembly there was no problem. I thought that the front doors were different (mk1 to mk2) because the armrests are mounted differently, but I have not tried it.
A1d1e
It's a 2.0 HDi Forte, Red. I'm based in Sheffield and have been assured by French Spares in Ranskill that Mk1 & 2 front doors are same.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
A1d1e wrote:It's a 2.0 HDi Forte, Red. I'm based in Sheffield and have been assured by French Spares in Ranskill that Mk1 & 2 front doors are same.
As Jim states the internals are different so you'll have some adaptations to do to make the door card to fit if you're using a Mk 1 door on your HDi, I think the door locks may also be different so you'll have to swap those over as well.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
