1.9 Turbo D fuel filter housing
Post Reply
Dommo
My Cars: Current
07 C5 VTX+ 2.2 HDi 173hp
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
91 Toyota Soarer UZZ32 Active Suspension
97 S1 VSX 1.9 Turbo D
99 Xantia Activa
98 2.1TD Xantia
99 306
x 19
Post by Dommo »
Hi all, I understand the 1.9TD fuel filter housing is known to leak air in via the thermostatic fuel heater system. I can't remember the procedure for stopping it leaking, was it to replace the small thermostat system, or just to replace some O-rings? If so, which O-rings do I need?
Thanks! Dom.
spider
My Cars: Soon, I hope...
x 77
Contact:
Post by spider »
Usually the one under the housing is the cause :)
Quick pic: (Item 8 in this)
Another pic that I had to hand (no seals shown on this one though)
These are 406 pictures, however it is the same.
Andy.
Dommo
My Cars: Current
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
99 Xantia Activa
98 2.1TD Xantia
99 306
x 19
Post by Dommo »
Thanks spider. I thought that seal was one of the culprets too. Need to get two on order, one for the Xantia and one for my 306!
Hopefully not too expensive. Cheers.
My Cars:
x 92
Post by citronut »
ignor this post in erorr
My Cars:
x 92
Post by citronut »
here is part No. and price
06
1912 11
RING-SEAL
DIAM 65X73
- DIESEL XUD9
DIAM 65X73
- TURBO DIESEL XUD9TE
DIAM 65X73
- DIESEL TURBO XUD9SD
08
RING-SEAL
DIAM 65X73
- TURBO DIESEL XUD11BTE
price £7.53
regards malcolm
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Post by citroenxm »
Weres the difference?? The Diamiters are all the same...still there must be something though.....
I understand later XUD11's had this mod, and its also something I wanted to add to my Series 1 XUD11, 1991 H reg XM, I hate the external type fuel filter system..
Paul
A very sad...
1994 XM 2.1 d auto
My Cars:
x 92
Post by citronut »
yes Paul you are correct,
i by misstake selectted the wrong item and it looked to me there were two types of seal :oops: ,
i thought i had deleted the wrong post but you know what thought did
regards malcolm
Dommo
My Cars: Current
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
99 Xantia Activa
98 2.1TD Xantia
99 306
x 19
Post by Dommo »
I forgot to update this! I also somehow totally forgot that I hadn't changed the fuel filter on the 1.9TD when I serviced and changed all the other filters. So I changed it and it seems sorted now which means I don't need to do the other seal which is always good.. We will be doing this job on the 306 though as that needs it doing. Looks like a messy job..!
spider
x 77
Contact:
Post by spider »
Dommo wrote:Looks like a messy job..!
It's not bad. Clean the area around it first (the aluminium housing, if you are taking the plastic housing off) , and just put a good rag around it to catch any fuel. Obviously drain the filter first to avoid excess mess.
Wearing gloves is a good idea too, getting the smell off your hands afterwards is annoying.
Andy.
Post Reply
