Xantia pressure regulator repair kit
rasputyn
Unread post by rasputyn »
All spheres are at proper pressure, no leaks, only little return on return pipes but regulator keeps clicking and clicking (every 4-5 sec.).
I guess it's time to find new o-rings and seals, it obviously can't hold pressure.
Any kits available online? ebay prefered.
Thanks lads.
x 94
Unread post by citronut »
hi and welcome
there are some on here who remove the bleed valve screw fully, with a tray underneath to catch the ball bearing,
place the bearing back in place if it came out, if not check its there in the first place, then with a copper drift give the the bearing a sharp blow to re/seat it, now re/fit the valve screw,
regards malcolm
davetherave
x 4
Unread post by davetherave »
There are others who would send it to pleiades for refurbishment.
I have just sent an FDV to them for rebuilding!
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
