Burning Coolant...
Xantia2.0
Burning Coolant...
Unread post by Xantia2.0 »
Yep, the thing all us drivers dread. The day we check our coolant and see it has went from the maximum mark to below the minimum mark in less than a week...
However I don't think it is the Head Gasket as there is no smoke, no noticeable loss of compression, and no oil in the coolant/coolant in the oil. I've looked through the history and in all its 148,000 miles it has never had a new Inlet Manifold Gasket. So I'm guessing a mixture of high millage and old age has perished the gasket.
Is there anything that could have caused the gasket to go ?
P.S. I got the wheel bearing changed :)
1998 Citroen Xantia 2.0 16V I4 with 148,200 miles on the clock. Bought it with 123,000.
spider
x 77
Unread post by spider »
Congrats on wheel bearing. :)
Its not leaking out is it ? , radiator probably prime suspect.
Some leaks (tiny pinholes) will only leak when warm and under normal pressure, making the difficult to spot (tell tale antifreeze staining is a good clue)
Probably take it to a nearby garage and get the coolant system pressure tested (they fit a special cap and pressurise the cooling system, leave it a short time and check to see that the pressure has not dropped) , that's certainly the 'easy' method.
Caution: if you have a component that is just 'starting' to fail, it can be made worse by this test.
I thought about using the exhaust analyser to sniff the coolant vapour but not too sure if this will work on a diesel actually. EDIT... Just noticed yours is petrol. Basically if there's any HC present in the vapour (do NOT let the probe have a drink!) then the h/g is probably failing.
Alternative is to have a block tester (fits in coolant bottle and fluid inside tester changes colour if gasses are present) although I've never really found these terribly reliable.
Personally, I would pressure test the coolant system first.
At least on a petrol the hoses around the back are (relatively) easy to get at, I remember on the XUD9 there was a loop at the lower end and it was horrible to fix due to no space (a bit like where the early XUD's had the fuel heater, but worse)
Andy.
Xantia2.0
It's not a leak as I've given the rad and hoses a good check. I am also sure it is the gasket as after giving the engine a good rev there is coolant sitting in the tail pipe and a green residue as well.
spider
x 77
Still worth pressure testing.
If its actually in the exhaust ( ! ) , there's a chance of a cracked head / block :( , not really sure how likely that is though.
Andy.
Xaccers
x 188
Unread post by Xaccers »
Check under the front foot well carpets for wet patches.
DIY sphere tool
spider
x 77
Xac wrote:Check under the front foot well carpets for wet patches.
I thought about that too, but figured if it was losing a litre or so it would be really bad inside and smell if not. :?:
Andy.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
What about the pressure cap? Invariably forgotten but often the cause in such cases.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
