Saxo rough running
merlin617
Saxo rough running
Unread post by merlin617 »
She who must be obeyed has a 1998 Saxo 1.0 manual to which I replaced the TDC sensor on advise of RAC chappy that she called out recently. On checking the car I pumped the brakes a few times in succession and the engine was nearly stalled.
I cannot hear any leak from the servo so am wondering if another sensor is the problem. Its got a new spark plugs, exhaust and lamda sensor. Any help thanks.
Xantia 1.8 Sensation Hatch 1999
Saxo 1.0 1999
Chris570
x 36
Unread post by Chris570 »
does it idle properly at start up from cold? or generally in fact.
Does the idle problem only happen when using the brakes?
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
merlin617
idles ok just rough when I pump the brakes a few times.
Saxo 1.0 1999
imperial21
Unread post by imperial21 »
Hi
There should be a 1 way vave in the servo pipe if i remember rightly, that can cause the problem you describe if faulty.
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
merlin617
Thank you both for your help
Saxo 1.0 1999
Chris570
x 36
i'm just trying to picture what you mean. the idle will change a little bit when pumping the brakes but that is only because the air/fuel ratio will change momentarily to bring the vaccuum back.
what exactly does it do? the crank sensor is only normally the issue if you have problems at high revs or when the engine is hot
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
