xsara 14 hatch heater blower
mred
hi guys the blower in the car has stopped working ive checked the fuse thathats ok and and when you turn the blower switch you can hear it go from recon to fresh vent . the car don ,t have aircon . any ideas thnx
- x 94
the first thing to check is the fan speed resistor pack,
im not sure were it is on a XSARA but on a ZX you gain access to it by removeing the plastic scuttle under the screen, then the pull the grill off of the fan air intake, not put your hand into the air intake and you will find a small metal cadge which you rotate about a quatre of a turn, then pull it up through the intake and unplug it,
well that is if it is similar to the ZX anyhow,
regards malcolm
regards malcolm
