Wheel bearing time...
Xantia2.0
Well the time has come when the front O/S wheel bearing has gotten as bad as I will drive it with. The whole car shakes around while driving, the noise is extremely loud, and the steering wheel vibrates VEEERRRRRRRYYYYY bad when driving over 50MPH. I did some checks to make sure it was just the wheel bearing causing those problems, and it is. The wheel is barely turnable by hand while jacked up! Feels like the brakes are binded on (though they're not). Is there anything else I should change/check while I'm getting to the bearing ?
1998 Citroen Xantia 2.0 16V I4 with 148,200 miles on the clock. Bought it with 123,000.
- x 8470
That one sounds bad!
Be aware that youll need a hydraulic press to extract the old bearing and to install the new one.
Don't believe the BoL. You'll need at least 7 tons of sustained pressure to extract the old bearing...
How exactly did you determine it was the bearing and not something else? I'm amazed the car was still drivable if the bearing is that bad. Normally, they give lots of notice of impending failure, starting off as a gentle hum...
addo
- Sara Watson's Stalker
- x 95
Xantia2.0
It did start off as a gentle hum!CitroJim wrote:That one sounds bad!
VertVega
- x 13
Re: Wheel bearing time...
I would suggest checking condition and thickness of the front brake disks.Xantia2.0 wrote:... Is there anything else I should change/check while I'm getting to the bearing ?
If one of them needs changing then you should remember to change both sides.
That's true, when the front wheel bearing of mine was in the press, it "banged" when the press meter was pointing at 12 tonsCitroJim wrote:... Don't believe the BoL. You'll need at least 7 tons of sustained pressure to extract the old bearing...
Xantia2.0
