'00 Xantia drop
LaLinea
'00 Xantia drop
When I start my car overnight and after work the rear drops down and come up again. Accumulator or the damper(?)spheres? No outside leak whatsoever.
'00 Xantia 1.8i Millenium estate
'96 BMW 328iA Coupe
Youtube in Myspace, and I'll Google your Yahoo
'96 BMW 328iA Coupe
Old-Guy
- x 33
If you have loaded/unloaded the car with the engine not running, it's quite normal for the rear to go up and down a bit when you restart.
Otherwise it's probably time for a new accumulator sphere - definitely if the tick rate (when the suspension has stopped moving) at idle is less than 20 seconds.
Try the rear bounce test - with the engine off, put some weight (a passenger) in the back; the rear will go down, but should come back up again within 30 seconds.
LaLinea
- x 8470
- x 1507
Old-Guy
- x 33
In a word "Yes". Should be nice and soft at the back. Driving around with little movement in the rear suspension is going damage the rear suspension.LaLinea wrote:So... I have to save for three spheres at the rear end then because it feels very hard at the back, never been changed before.
Yes they should; a sign that the hydraulics are in good condition. When filling up with fuel, the car should slowly sink; 25-30L should be enough to 'trip' the height control valve so the car starts to rise even though more fuel (weight) is going in. It something to watch for every time you fill up.Tought Xantia's dont rise with the engine turned off?
The boot test is a bit more demanding: With the engine off, sit in/on the back end of the car. It should sink quite a long way. After about 20 seconds it should start to rise - all the way to normal height; then get out/off. It should immediately rise, then after about 20 seconds settle back to normal. You should be able to repeat the whole cycle at least once more (using accumulator pressure).
If it doesn't sink or rise much - corner spheres flat(ish).
If it wont rise at least twice - new accumulator and/or anti-sink need changing.
LaLinea
