Hi, ive got a peugeot 607 2.2 HDI, ive fitted a replacement engine which came with the diesel pump, the car is not cranking over and goes into economy mode.
Is it true the diesel pumps are coded to the ECU and a replacement 2nd hand unit wont work with a different ecu
"2005 Peugeot 607 HDI not starting
spider
- x 77
As far as I know, yes you are right. You cannot just pop another pump / engine in.
It's probably possible to have it all re-coded though, you need someone with Planet / Diag or possibly a Lexia might do it.
Andy.
emc4raz
spider
- x 77
I think it is but cannot be 100% sure.
Ideally you need to find a member on here with a Planet (or at a push a Lexia 'might' work but I'm not sure as that's Citroen) to attempt to 'code' it, nothing to lose as it does not work now.
Here's a list > http://www.frenchcarforum.co.uk/forum/v ... hp?t=26807
Andy.
emc4raz
cachaciero
- x 9
Re: "2005 Peugeot 607 HDI not starting
O.K car is not cranking that could be due to many things bad battery, mismatched security codes however that should give you a warning least ways does on the C5. The electrics will automatically go into economy mode after a certain time, this time is programmable in the BSI so may vary between cars.emc4raz wrote:Hi, ive got a peugeot 607 2.2 HDI, ive fitted a replacement engine which came with the diesel pump, the car is not cranking over and goes into economy mode.
Assuming that this is the same Bosch injection system as the C5 the pump is not coded, the pump does not have an ECU. The injection ECU is coded and cannot (easily) be swapped between cars.
The injection ECU will need to be told what class injectors are fitted, don't know how much difference this makes to actually getting the engine to run.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
spider
- x 77
That's a point. The injectors would need coding otherwise they will not work at all (unless they are the original ones from the 'dead' engine and they went back in the same places)
Although getting them out can be 'fun' from what I hear.
Andy.
emc4raz
Injectors were from the existing car, spoken to a few ppl and the main dealer and the diesel pump is not coded and will go straight in. Mechanics gonna take a look at it again tommorow, do you know if the injectors will need to go in the exact order as they are numbered. Been told it should start atleast even if they are in a different order.
cachaciero
- x 9
Shouldn't make any difference if they are all the same class.emc4raz wrote:Injectors were from the existing car, spoken to a few ppl and the main dealer and the diesel pump is not coded and will go straight in. Mechanics gonna take a look at it again tommorow, do you know if the injectors will need to go in the exact order as they are numbered. Been told it should start atleast even if they are in a different order.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
emc4raz
cachaciero
- x 9
Do you have fuel to the filter bowl? or better from the filter to the HP pump?
cachaciero
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
emc4raz
emc4raz
Cars running now, but lack of power and anti pollution fault appears, been told too drive the car at about 50-60 mph for a little while to clear it up.
Also after the car was running for some time, i turned it off and left for 10 mins or so, started back up was reving the car for quite some time is well a load of white, clear smoke appeared, than dissapeared after a little while. Could that be from the clogged filter.
emc4raz
- x 5624
