ZX front brakes
timbo2410
ZX front brakes
Also while I think about it. The front pads and discs are nearly ready for a change. Is there a better "BOLT ON" product than the standard 1.9 Reflex brakes? I'm running the stock wheels as well (13 inch) ... I don't want to make any modifications other than to just bolt on if you get my point
Chlorate
EBC offer some interesting upgrades on discs and pads.
http://www.ebcbrakesdirect.com
I'm using greenstuff pads with stock discs, they tend to squeal a little bit until you warm them up but they really do the trick.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
timbo2410
evilally
- x 3
As suggested, I would try better pads first of all, and give the brakes a good cleanup and fresh fluid. I have greenstuffs on my 405, I would say a reasonable upgrade over standard (although mine have never squeeled?). I've got Ferrodo DS2500's on my Clio, and they are awesome
I suspect with a 13" wheel your options will be limited anyway, and bigger calipers won't always give you better performance if you're using the same master cylinder.
'97 406 1.9TD, 314k.
timbo2410
