ZX Dashboard lights
timbo2410
ZX Dashboard lights
Hi all, I have a Citroen ZX that has a few bulbs out behind the speedo. I've looked at a few forums to see how best to sort these out. Now I can get to the two screws without having to take off the steering wheel shrouds, so I think that will be the easy part. I am worried about the speedo connection though. How does it come off before removing the instrument panel. The Haynes manual is as clear as mud on that part. Also, how many bulbs do I need to replace the lot? I have been told by Citroen dealership that I will need 10 bulbs and also 10 bulb holders. If I get it done through them it will cost £130 approx. for parts and labour. Any thoughts?
Gingerposer
- x 6
I did this job a few years ago on my zx td. I hope you have small hands!
To make it easier, lower the steering column to its lowest position before starting the dash removal. You will have to try to tilt the clocks towards you or to one side to reach the speedo connector, if I remember correctly this is the type where you apply pressure to two lugs on the connector, which fits into the centre of the back of the clocks.
I think there is a separate connector for wiring.
The bulbs themselves are a piece of cake to replace but do them all - cos guaranteed you will just have replaced one or two, got the dash back then spot another couple of dud bulbss!
You probably need about a dozen to do every bulb. A good source of the bulbs is ebay - do a search for fruit machine bulbs, you will probably pick up 100 in a sheet for a few quid.
Or if you send me an sae I will send you however many you need!
Ainslie
Ainslie
timbo2410
timbo2410
Would these be them?
http://www.autobulbsdirect.co.uk/R286-D ... teid=47683
Gingerposer
- x 6
aye that's them - but 99p each? that's daylight robbery! the going rate on ebay if you search for fruit machine bulbs is about ten p per bulb if you buy a sheet of 50 or 100, which is what I did. Unless you want coloured bulbs of course. If you are happy with clear, pm me your address and I'll send you a dozen free.
Forgot to ask, what is your location? Someone might be near you and able to help with the job.
Ainslie
Ainslie
timbo2410
Gingerposer
- x 6
Going from memory, the bulbs in the instrument cluster are held in by holders, which the spade bulbs simply push/pull into, so changing is easy. Twist holder a little, remove holder, remove bulb, replace bulb etc. You may find that some holders are empty or that some holes which look like they should have holders, don't have holders in. I think this is because of the different specs available i.e. rev counter etc - so I would just change every bulb you can find, one at a time, or you could have a nightmare job if you get the holders in the wrong places.
I think the only bulb which needs to be a specific colour would be the low fuel warning light, cos it may have a yellow film in front of it to give the correct colour to the driver - if you change it you may not notice running low on fuel (yes, been there, done that, oops). This could also apply to the high temp warning light, so best to find out where these are located before making any colour changes.
Ainslie
Ainslie
timbo2410
Ha never even thought of that. I thought those warning lights would have been a neon light or something a little more gauranteed to work and never fail ... Hmmm that means I may have to get some yellow or red as well. I've got the bog standard ZX 1.9 D with no rpm or anything else other than the speedo, fuel gauge and clock.
spider
- x 77
The green effect (assuming its green) is done with perspex in the panel (the same with the reds / yellows, again perspex)
Changing bulbs to colours other than clear will be interesting, (colour shading)
Andy.
timbo2410
Ummmm so where does that leave me ... are all lights clear bulbs then? Including the pre-heater, oil pressure charge light etc etc ? And is it just the low fuel warning that is amber in colour?
If the warning lights are behind coloured perspex, then they will have to have clear bulbs, the lights that illuminate the speedo, clock, odometer can be whatever colour I wanted I suppose.
Oh forgot to ask, does anybody know exactly how many bulbs are needed?
jgra1
- (Donor 2021)
- x 37
timbo2410
jgra1
- (Donor 2021)
- x 37
timbo2410
jgra1
- (Donor 2021)
- x 37
