Xantia 97 More help Please!
morph_1904
Unread post by morph_1904 »
Right new problem;
Thanks for your help on the last problem that is now improved but ongoing,
I was fool and thought it would be nice and straight forward, ( i Should have known better)
Fitted in the new radio just by swapping over the iso connectors leaving off the remote connectors and of course put in the radio aerial.
Now i have no dash illumination at all. except the window switches.
any ideas whats caused this? fuses are fine and i have replaced to make sure to no avail.
Thanks in advance
spider
x 77
Unread post by spider »
I would say you had blown the illumination fuse but you said you checked them.
The window switches will come from the ignition supply so they will not be effected.
I don't think there's a loop effect with the illumination feed.
Check any dimmer for the panel lights, not quite sure where this will be to be honest, maybe on the bottom of the column cowling (off topic note: 405's have it here) , you may have caught it which would give the effect of no panel lighting.
Andy.
Old-Guy
x 24
Unread post by Old-Guy »
Spider's last suggestion is the most likely and simplest explanation; the panel dimmer control. It's a 'wheel' (as on a wheel-mouse) set in the bottom steering column cowl towards the back right - nearer to you than the bonnet release. It's very easy to accidentally turn it fully dim.
morph_1904
sorry guys i should have said in my post that i have checked that too it annoys me cause i keep moving it when i go for the bonnet pull ! lol it the dimmer does not make any difference,
jgra1
(Donor 2021)
x 37
Unread post by jgra1 »
Morph are both wires still plugged into that dimmer switch? if one gets caught and pulls out you may lose all lights.
John
spider
x 77
jgra1 wrote:Morph are both wires still plugged into that dimmer switch? if one gets caught and pulls out you may lose all lights.
John
Mine (205 but same place) used to flicker. I ended up just joining them together, simple fix.
Andy.
morph_1904
they are both connected solidly
spider
x 77
morph_1904 wrote:they are both connected solidly
Unplug the rotary dimmer switch, switch the lights on and check that one side of it has power (use a multimeter or test light)
Andy.
morph_1904
i am at work atm but i will try and sort it out before i go home and try it.
spider
x 77
Just simply said to test for power to one side of it, as its not unknown for them to go open circuit.
If you do have power at one side, temporarily (if you want to) join them together to bypass the dimmer. At least this way you`ll know its not that interfering with it (and if they work like that you know the cause) :)
Andy.
morph_1904
as i am at work i will just try and short them and see if the lights come on its getting dark and i want to see what speed i am going on the way home!
morph_1904
ok couldnt find a meter or lamp tester at home so i tried to short out the dimmer and still no dash lights. could it be the wireing on the radio? i just plugged in the iso connectors without any extra wireing.
jgra1
(Donor 2021)
x 37
I guess so Morph, as the stereo does have the lighting circuit running through it.. never heard of it happening before..
worth unplugging it I guess>?
morph_1904
i am not sure what to do no the wires are in the iso which one do i remove how do i get it out of the iso plug?
jgra1
(Donor 2021)
x 37
I would just take them all plugs out and see ?
