Xantia key lost - new key doesn't start car.
aerodynamica
x 215
Unread post by aerodynamica »
A friend of a friend lost the ignition key to a Xantia 1.8 petrol. I think he has got one from a dealer but it will not allow the engine to start.
I think the starter turns over but perhaps the ignition needs a signal from the transponder in the key?
How can you get around this?
Any help greatly received!
Graeme
Graeme M
x 8202
Hi Graeme,
If it's a MK2 then the key needs the transponder chip and this needs programming. For this you'll need the PIN number that came with the car and a Lexia.
Does the immobiliser light in the tacho go off when you switch on the ignition and try a start?
If you don't have the PIN (it comes on a credit card) then you'll have to get it from a dealer after giving the car's VIN and proof of ownership.
It can get expensive.
No real way to bypass the immobiliser on a MK2.
This does not apply to a MK1.
aerodynamica
x 215
Cheers Jim, I'll look into it. I don't know if I can get a Lexia though - might be able to source one.
All depends on if the PIN is with the car!
Graeme M
x 5615
For someone to do a Lexia diagnostic and reprogram your keys, look here.
You are quite fortunate in having two close at hand :)
aerodynamica
x 215
Ah thanks - DHallworth in Glasgow! I am certain I've chatted with him before as I recognise the name.
Well I only hope this PIN number is available.
Graeme M
DHallworth
x 163
Unread post by DHallworth »
If you can get the PIN code then feel free to give me a shout.
I'd probably need someone from here who has used the Lexia before to give me a heads up on how to do it though!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
x 94
Unread post by citronut »
yep Dave
you go into the learning section on the LEXIA, i cant remember exactly were you find it , but its in there somewere :oops:
regards malcolm
x 8202
citronut wrote:yep Dave
I think you'll find it in the Replacement Parts menu, the same place as where you go to flash an ECU.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
No, I dont think its in there Jim, but even though Ive done it on a HDi im not 100% certain...
I know its called "LEarning" or "Key Learning". The on screen instrctions are reletivily clear..
I managed to add a PLIP for Locking the car with the Lexia, but didn't get as far as getting it to start the car...
Paul
A very sad...
1994 XM 2.1 d auto
x 94
ooooh FLASHING!!!!!!!! E C U Jimmy
regards malcolm
x 8202
citronut wrote:ooooh FLASHING!!!!!!!! E C U Jimmy
I just knew that would elicit a comment from you Malcolm :lol: :lol:
Paul, thanks. I'll have to go and fire up and find it. Got me all curious now...
