Hi Guys,
Sorry to post another central locking issue, but I can't find the solution for my issue...
I have recently bought a 2002 Saxo Desire for the work run. It's a great little car and flew through its MOT, but the central locking doesn't work.
When I press the fob, nothing happens.
However, when I turn the key in the door, only that door opens, not the passenger door (I had a 106 years ago, & I vaguely remember the central locking fired when you unlocked the drivers door).
So I'm not really sure where to start - Has anyone got any pointers as to where to start? I don't really want to take it too a garage as it was only a cheap run about...
Thanks in advance
Tom
SAXO - Central Locking Issue
spider
- x 77
First step, check fuses (probably above glovebox area, they are on a 106 anyway)
Next, (silly question I know but its been known) do you actually 'have' central locking ? , its quite possible to just fit the button part of the key...
I don't think these suffer with wire breakage in the door shut area of the loom (306's do)
If it has remote locking it will have a solenoid on each door and one for the hatch. If its non-remote locking it (might) NOT have one fitted to the drivers door, as just the switch will be there to 'trigger' the other ones.
First steps, check fuses. Next, whip a trim panel off to confirm you do actually have c/l. The hatch panel / boot lid one is probably the easiest one to take off at a guess.
Andy.
