Renault Espace V6 - Door lock issue.
R9UKE
x 3
Unread post by R9UKE »
Bit of an annoying fault with the Espace. When the lock button is pressed, ONLY the boot and passenger door actually lock. The two back doors and drivers door remain open.
Also, the little pocket under the drivers seat is wet (the footwell isn't) and the radio doesn't work (probably due to the same leak as the stereo is located under the drivers seat). Any ideas?
Thanks.
French is best.
