Polish inside the doors
Old-Guy
x 26
Unread post by Old-Guy »
No, I'm not being obsessive!
I've eventually got round to replacing the seal over the O/S doors that apparently ripped when it froze to the rear door (before I had the car).
I've found with other cars that the cure for doors sticking to the weather seals on frosty nights is to thoroughly wax polish that part of the doors and the tailgate/hatch where the metal meets the seal. The idea is that this treatment makes the paintwork water-repellant - ice may still form, but it won't adhere to the polished paint.
I've seen WD40 or similar suggested as a quick and easy alternative; it probably will do for a while until the solvents rot the seals.
handyman
Unread post by handyman »
Hi Guy, have you tried KY jelly? No, not in your private life. :roll: On your door seals.
Just a thin smear works wonders, but you can pile it on if you really want to get "dirty". :bl:
Or petroleum jelly/Vaseline.
H
x 5672
handyman wrote:Hi Guy, have you tried KY jelly? No, not in your private life. :roll: On your door seals.
H
Sounds a good suggestion, especially in combination with spotlessly clean/waxed & polished door shuts.
I'd avoid Vaseline/petroleum jelly as it will degrade the rubber seals.
Silicon lubricant is another consideration - expensive though.
colinxm
Unread post by colinxm »
Over here in Norway it is common practise to coat all door rubber seals with silicone spray before winter begins. I should think that Halfords would have the small sprays produced by turtle wax that are common here along with many other suppliers. The stuff works wonders and leaves the KY jelly free to be used elsewhere... fitting cv joint rubber gaiters for example :wink:
Colin.P
1995 Cit XM 2,1 TD Silver Estate
2004 Pug 307 SW
1989 Pug 205 Cabriolet
1998 Ford Puma
1979 Triumph TR7
davetherave
x 4
Unread post by davetherave »
Something I also need to get round too, still havnt fixed a seal that got frozen last year!
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
uhn113x
x 3
Unread post by uhn113x »
davetherave wrote:Something I also need to get round too, still havnt fixed a seal that got frozen last year!
Not got round one yet, Dave, mine's Old Peculier :D
I use Vaseline on door rubbers.
Mike in West Yorks
1982 GSA Pallas
1982 Dyane
1997 ZX Dimension
steelcityuk
Unread post by steelcityuk »
As a matter of course I always polish the door, boot and bonnet shuts to provide a measure of protection for the paint work and it tends to keep them cleaner because it's harder for the grime to stick. A wipe over the rubber and plastic parts with Armour All or such protects them too.
Don't get me wrong I'm not obsessive about polishing cars, twice a year's enough for me.
Steve.
not applicable
Diabolical
Unread post by Diabolical »
I use Vaseline not realising it's bad for rubber, now means lot of hard work getting it off and replacing with silicone.
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
