Changing HP pump seals?
Dommo
x 20
Unread post by Dommo »
Hi folks
I was wondering whether there was anything special I need to take into account in taking out the high pressure pipes out of the HP pump on a '97 VSX 1.9TD? Are there any spring loaded bits that will fire out at me??
Thanks, Dom.
x 94
Unread post by citronut »
there is a spring,plundger and ball bearing in under the pipe adapter that the seal is under,
but as long as you are carefull it will not fly out, also put a tray under the pump and clamp the rubber supply pipe, as the will reduce the flow of citro blood,
regards malcolm
Dommo
x 20
Thanks Malcolm.
My dad tackled this job yesterday while I was still at work using some caution! The new seal along with a new accumulator sphere appear to have stopped the leak at the HP pump.
Thanks again.
