picture and list of what fuse is what
Pompey_Dave
Unread post by Pompey_Dave »
i opened up my fuse box the other day to try find out which one is for the rear window, as its still not heating, but there is no diagram or listing of what fuse is what....just a load of fuses
anyone got a picture with listings of each fuse please, then I can try figure out what one is the one im looking for, aswell as knowing what the others are in case I need them later on
thanks
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi Dave,
Prehaps before looking at the obvious, what about loking for the forgotton??
Check your wireing between the hatch and roof, at the rear, open the boot, and you'll see the two grommets in each corner going into the roof... Try pulling the grommets back and seeing if theres any broken wires!
Paul
A very sad...
1994 XM 2.1 d auto
Simon99
Unread post by Simon99 »
According to Haynes,
if its a xantia for models upto January 1998:
F23 10A Heated rear window switch, heated seat switches
F27 30A Heated rear window, heated mirrors (power supply)
For models from January 1998:
F5 10A Heated rear screen switch, daytime running lights relay, heater blower relay, heated seats relay
F29 30A Heated rear window, heated mirrors
If you can find your owners manual believe theres a list of fuses in there.
2002 C5 2.0 16v Estate
2001 C5 2.2hdi Hatchback
1998 Xantia 1.9td Estate
Pompey_Dave
dont have a manual for the car
As for looking at the wiring, thats something for the garage I bought the car from to look at lol! I just thought fuse as thats a 2second job and esier for a thicko like me to notice if its broke or not haha!
Xaccers
x 188
Unread post by Xaccers »
Does the cabin fan blow?
There's a known issue with MK1 Xantias (can't remember what you've got, update your signature to let us all know) where the ignition switch burns out enough to stop the fan and rear heater working.
It's a simple fix.
DIY sphere tool
Pompey_Dave
yeah, everything else seems to work, and the fans were sorted before I bought the car as I mentioned that the fans werent working and the air con didnt when i was testing the car out
The car is the Mk2, 1999 1.8 lx
