Take the car for a drive when you turn-off the engine but leave the ignition on the stop warning light comes on starts to flash & beep
it doesn't come on with engine running
is this norm or a fault on it
its an 02 1.9d 96k
thanks jim
combi partner stop warning light
spider
- x 77
I half think that's normal, although I'm working from memory.
It will flash on and off when driving ( ! ) if a door is ajar etc
Hopefully someone can confirm for sure. If its NOT on when running, its usually not a concern, it should come on with the ignition anyway (partly as a bulb test and partly as its wired through things such as oil pressure warning light etc) , in these cases it tends to be on rather than flash
Andy.
