risk of Filter Blocking
citrokid
got the above message this week on the dask and the service light on
C5 1.6 HDI year 2005
had a look with lexis ver45 , no faults, then cleared fault log and still have the message.
any ideas?
any ideas?
bencowell
bencowell
Has it ever had a top up of the EOLYS fluid? If you're a Lexia owner look at the thread on here as some people are discussing disabling the system.
Currently driving a 2004 C5 VTR (old shape) and an Electric Kia Soul. Sorry but the electric one is my favourite!
Formerly Hyundai Genesis 3.8 V6, 2 x Kia Optima, 2 x C5, Xsara and Saxo.
citrokid
mooseshaver
Usually that message means you need to drive faster than 30 or 40 mph for a while. I think the manual for my 2.2 suggested it was likely in slow moving traffic.
If you have a lexia can you force a regeneration of the filter? Do you do a lot of town driving?
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
Onlinemyglaren
- x 5672
Forced regeneration is no fun at all and guzzles loads of fuel.mooseshaver wrote:Usually that message means you need to drive faster than 30 or 40 mph for a while. I think the manual for my 2.2 suggested it was likely in slow moving traffic.
Here's a description from the Honest John forum - for Renault but the same applies.
the whole thread
In this case, the advice given is the same as that stated in the drivers handbook:
In order to enable the particle filter to be cleaned, we recommend that you drive the vehicle as soon as possible until the waring light goes out, at an average speed of 50mph (80km/h) providing that the following conditions allow it:
traffic conditions
legal speed limits
Regeneration typically takes about twenty minutes from the moment it starts, if the driving conditions remain favourable. The warning light or the message will then disappear. Nevertheless, if these instructions are not observed, a second warning (service warning light + Injection warning light) may appear. It is recommended in this case that the vehicle be returned to a Renault dealer as soon as possible to carry out a forced regeneration.
citrokid
Onlinemyglaren
- x 5672
citrokid
drove about 160 mils in the last 2 days. drove in 4th with rev's at about 4000 fro about 15 minutes.
checked with lexia this evening, soot load down to 33% from 58%
differential pressure at about 78 mbar with engine at 3000 revs, and fluctating with engine speed. addative lo level not reached but i still have the message "risk of filter blockage" and the service light on .
All above would indicate reasonable operation ?
Any ideas as to what should be my next course of action?
bencowell
The car tries to know what sort of driving you do. Perhaps it's just confused. I'd disconnect the battery for 10 mins and see if that changes anything.
cachaciero
- x 9
I wouldn't have thought that those figures were high enough to give a warning, however temporary faults often require three run start cycles before the message gets cleared. Clear the error with the Lexia and see what happens.citrokid wrote:drove about 160 mils in the last 2 days. drove in 4th with rev's at about 4000 fro about 15 minutes.
If all else fails you have a Lexia therefore you can run a forced regen just make sure the back of the car is clear before you do.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
citrokid
cachaciero
- x 9
Any fault which occurs will should get latched into the ECU error memory this fault will also set the service light and also set a message such as "Anti Pollution" fault. (C5)citrokid wrote:can you explain three run start cycles , I cannot find any errors with the lexia that relate to these faultshowever temporary faults often require three run start cycles before the message gets cleared. Clear the error with the Lexia and see what happens.
For each start the ECU logic will check the error memory and then check if the fault is still present, sometime after starting if the fault is not present and does not re-occur a counter is incremented when the counter equals three it will cancel the service light and any associated messages. The fault remains in the error matrix and when the ECU is read with a Lexia the Lexia will flag it as a Temporary Fault.
I just had a thought the above refers to a Bosch system I think that the 1.6 has a Siemens system so what goes for the Bosch system may not apply.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
citrokid
