Xantia: Pump, Regulator or Doseur fault?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Scenario: "STOP" light and buzzer almost constantly on when driving. Pump running almost constantly. Rear dips when braking, and is slow to recover once stopped.
Good LHM fluid level, no leaks larger than persistent occasional drips from the reg return, 55+ Bar in the accumulator - tested today.
Is brazing a safe way to tee into hydraulic lines for a (temporary) gauge fitment?
Thanks, Adam.
x 1240
Unread post by Peter.N. »
Hi Adam
Check the return pipes to the LHM reservoir, sounds as though you have quite a high leakage on something. If its happened suddenly I think it unlikely that it would be deterioration of the supply system.
I have silver soldered a hydraulic pipe which is about the same temperature as brazing so I would think it was OK, you really need a proper 'T' piece to put in for strength.
addo
x 95
Hi Peter, looks like it was a dying rear corner sphere. I rechecked the LHM and no visible signs of heavy loss - yet it was now down more than half a pint.
I'd been conned on the fluid level, by only glancing when the car was depressurised for accumulator removal/testing.
Found a nice gauge for $45 that goes to 400 bar; should be good for testing pump feed pressure.
addo
x 95
Bad to worse? Definitely a crook sphere, but the doseur inner seal has expired, too - I've now the "100K mile LHM footwell event" signed off in my book.
Looking forward to an enforced cleanup of things!
x 8391
That's nasty Adam,
LHM in a footwell makes a horrible mess :twisted:
Get to it quick or it'll start eating the sound deadening on the floorpan and turning it to a gooey black mass :twisted:
Been there, done it, got the teeshirt :(
On the plus-side, LHM washes out of the carpet and foam reasonably well...
addo
x 95
I'm already blotting it up, carpets/foam out and sprayed with laundry degreaser.
Think I'll do the big jobs all in one go - new firewall insulation, heater core, evaporator.
Do you think braking technique affects the seal's life? I brake hard and sharply for weight transfer or to force a downshift, but seldom hold the pedal for more than an instant - prefer to let the gearbox and chassis geometry take care of the rest. Wondering if those who feather the brake enjoy a longer seal life.
