ZX turbo diesel
louis1
ZX turbo diesel
hi the rear suspension creeks alot especialy when you get in or out of the car does this mean the suspension has ad it or not. Also there is an oil leak on but i cant figure out where it is coming from, facing the front of the car on the right og the engine under the intercooler i can see traces of oil, if i clean and go for a drive it comes back, it is coming from above the head gasket, it is not the intercooler because it is dry around there and i have just changed the rocker cover gasket and used sealer but it still leaks, what can it be?
Dave Burns
sooty
It maybe your brakes making the noise when applying the handbrake then getting of the car and the suspension rising and turning the wheel slighty, this depending how hard you have put the hanbrake on.
Have you tried getting out of the car without the handbrake on and leaving it in gear to stop it rolling.
sooty
sooty
