hi fellow citroen owners!
i have a 1999 xantia 2.0hdi estate which has just developed the following fault.
symbol of an engine is lit up and car seems to have have lost power, this happened while driving to leicester from kings lynn. engine does not misfire or anything, just seems down on power. car is overdue for a service [display with spanner icon is flashing 0000] could this be anything to do with problem? any ideas anyone?
engine management light on/ lack of power
jgra1
- (Donor 2021)
- x 36
hi Carpy, I am afraid I have never yet needed to know anything about HDi's.. but for sure the light on is telling you of a fault, and the car has gone into 'limp home' mode..
once fault has been corrected you should get your power back
a session on a diagnostics is probably the answer.. a few of us have them, on here
John
John
carpysmith
carpysmith
cachaciero
- x 9
It will do that for an intermitent fault but the fault code will be locked into the ECU and can be read by a Lexia or other code reader.carpysmith wrote:warning light has gone out all by itself and all is well again!! whats that all about then?
regards steve (aka carpysmith)
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
carpysmith
obviously some sort of intermittent fault then! cheers for the info, i have a friend who runs a garage that specialise in citroens and have the appropriate diagnostics kit, gotta book car in for a service so will get him to run a check on it at the same time, at least i,ll know what fault is/was!
regards steve (carpysmith)
