Had my glow plugs changed a few weeks ago and the very next day the car wouldn't start for my wife. I strolled out and managed to start it first time, so, naturally I blamed my wife! Had been fine since until....
Saturday we all piled in the car ready for a quick trip out and again it wouldn't start. Eventually boiled a kettle and poured it over the plugs and associated fuel lines. Car started, probably coincidence but you never know. Yesterday we drove out to a forest park. Car started perfectly in the morning, but after standing for 5 hours I tried to start it for the journey home. It really didn't want to start. Just befiore the battery died the engine caught and I managed to keep it going. After a few seconds it ran fine. Obviously the problem is intermittent which doesn't help. My non-mechanical brain suspects that it might be the feed to the plugs. Does that sound likely? Secondly, if this is a possible fault would it be possible next time it plays up to connect a jump lead from the +ve battery terminal onto the plug feed bus bar for a few seconds and see if it will start then? Or is this a stupid idea?
I know I can rely on you guys for help on this so I will thank you in advance!
Cheers
Edit: forgot to mention that when it eventually started each time there were huge clouds of whitish smoke engulfing the general neighbourhood. I guess this is normal when it won't start as it is fine when it does start.
Intermittent poor starting
JohnD
- x 72
Re: Intermittent poor starting
During the summer and after only five hours, you shouldn't have needed the gloplugs so maybe your trouble isn't that. Before your next cold start, open the bonnet and give the primer bulb a few squeezes. It should feel fairly firm.Penguin wrote: but after standing for 5 hours I tried to start it for the journey home. It really didn't want to start. Just befiore the battery died the engine caught and I managed to keep it going.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Penguin
Hi John
Just a couple of things I need to add. On saturday when it wouldn't start I did try priming the bulb after each attempted start and it didn't seem to make any difference. Also, ever since I've had it, it did seem to require heaters even when warm, although not so much as when cold.
95 Xantia 1.9td SX
- x 5673
Penguin
- x 5673
It was excellent (I take no credit, was like that when I bought it)Penguin wrote:Yours is probably in better nick than mine!myglaren wrote:My son's 306 1.9 D-Turbo always needs the glowplugs.
My Xantia 1.9TD only needed them first thing each day.
>140,000 miles and ran like a sewing machine, in concourse condition too.
RIP Xant
- x 1240
Penguin
Thanks for the input Peter. What makes you think that is the culprit? Also, would it respond to a tw@tting with a hammer?Peter.N. wrote:Sounds like a dodgy fuel solonoid to me, if it doesn't have a keypad, dead easy to change.
Also, is there anything fundamentally flawed with my idea of using a jump lead from battery to glow plug bus bar? Would it damage me or the car? Just for elimination purposes you undertsand.
95 Xantia 1.9td SX
Old-Guy
- x 26
I have/had exactly the same problem, but patience and decent fuel are the twin answers. Probably I should change the injector tips.
Our 1.9TD always needs the glow-plugs, then starts very promptly. Hustle the lady to start and she will always refuse. On very cold mornings, she requires a bit of warning in the way of a dummy run - wait for the air-bag warning light to go out, switch off, wait 10 seconds, switch on, wait for the air-bag warning light to go out, then stir.
Clouds of 'white smoke' is a fine mist of unburnt diesel. You could try some injector cleaner (don't over-dose) and usually buying Shell or BP.
Penguin
Thanks for the input Old-Guy but this is definitely an intermittent thing. Yes, she pretty much always needs heaters and I have no problem with that, but it is the fact that 3 times in the last month (and twice in the last 2 days) she just wouldn't start. In between those 2 times - no problem. Even when starting from cold sunday morning. The problem first appeared the day after my plugs were changed, which is why I am still suspicious of it being a plug issue - I just don't like coincidences. But if it is a plug thing then it is something that effects all of them as I have successfully started on 2 plugs and that gave me a completely different experience to this one.
95 Xantia 1.9td SX
- x 5673
Xaccers
- x 188
Good point steve, I believe Xantias need glow plugs which can handle extended heating, fit the wrong ones and they get burnt out very quickly.
DIY sphere tool
DIY sphere tool
Penguin
Xaccers
- x 188
It could be depending on how they've failed and how many have failed.Penguin wrote:Don't know Steve, I didn't fit them. I had them done by an independent Citroen specialist.
Xac, if they burnt out then it wouldn't be an intermittent problem would it?
I started getting intemittent starting issues with Cassy not long after I got her and changed the leak off pipes (they get old and let in air causing starting problems) and glow plugs.
Using jump leads to test the plugs, they were sometimes glowing at the tip, sometimes at the shaft.
If you happen to still have the packaging or know the model of the plugs that can help exclude the likelihood of them being burnt out.
DIY sphere tool
DIY sphere tool
Penguin
