'98 Xantia 1.9 TD Estate - PAS Pipe
Malcolm
Unread post by Malcolm »
Hi again,
I am looking at this failed pipe, as I said in an earlier post, someone's replacement of metal pipe in inner-wing has disturbed rubber pipe attachnent and subsequent pipe detachment/blowout.
Does the required replacement rubber piece - 00004023G4 HYDRAULIC TUBE (thanks RichardW) come with the attached metal pipes machined to it or does the rubber piece detach from the fine bore metal pipes?
Sorry Richard. You mentioned - (from pump to rack) as you say PITA
Malcolm
'98 Xantia Estate LX - RIP 13/08/16
'08 Renault Trafic 115dci
