Citroen xantia suspention
netty
Hi there everyone i have just brought an s reg 1998 xantia before i picked it up the car sale had the suspension done but when i test drove it i found it bumpy and hard over bumps had a head ache when i got home. The bloke i brought it off said he will send it back to the garage next week but i just want some info so i can see if the garage did its job last week.
Toby_HDi
- x 3
Welcome to Xantia ownership and the forum netty
First things that spring to mind would be flat spheres or a broken height corrector linkage.
Both easily rectified. Plenty of info on the forum if you perform a search.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
- x 94
Xaccers
- x 188
Ok, so being an SX it has non-hydractive suspension (makes things a tad simpler).
Either the spheres are flat or the height adjustment isn't right.
Changing spheres is easy, and about £22 each. You have 6 in total, 1 on each corner, one at the front of your engine which is the accumulator sphere which stores pressure should your aux belt snap, and one at the back up behind the spare wheel which is known as the anti-sink sphere because it was fitted to cars with anti-sink and is a rear accumulator.
Check that the front accumulator is good by idling the engine and listening for a tick/click/clunk at the front of the engine, there should be at least 30 seconds between ticks. Anything less and it needs replacing, and is a good idea to replace the anti-sink sphere too. Also check around the large black nuts with metal pipes coming out of them on the hydraulic pump as these tend to leak by now, replacing the o-rings inside is a doddle and about 70p each (although some dealers insist on you buying a pack of 5). If you're not aware, your steering, suspension and brakes are all run from the same hydraulic system (steering comes from a seperate output on the pump), and you check LHM level with the car set on high.
The height corrector at the rear (and sometimes the front) can seize up due to lack of lubrication and hold the car at the wrong height giving a firmer uncomfortable ride. In extreme cases the plastic link (looks like a dog bone) can pop off.
NEVER GO UNDER A HYDRAULIC CITROEN WITHOUT THE PROTECTION OF AXLE STANDS!
They can sink suddenly and squish you.
DIY sphere tool
DIY sphere tool
- x 1459
netty
Old-Guy
- x 25
Hetty, to advise you further we need some more information about the ride height at the back.
Because Xantias have self-levelling suspension, they should always sit level. On a flat level surface, the sills should be parallel with the surface.
If the car is level but the rear suspension is hard, one or more rear spheres needs replacing. If it's sitting tail-up, then the rear height corrector mechanism is stuck and/or the plastic (dog-bone) link is disconnected.
You really need an independent Citroen specialist to advise you.
netty
