106 1.5d oil leak and clutch issue
KP
x 27
Unread post by KP »
All,
Colleague at work has a 1.5d and his clutch makes a wierd clicking noise when engaged now and also has an oil leak from the flywheel end of the engine. It looks and smells like engine oil and im wondering if the engine block seal at that end has gone and is causing the noise and leak?
Is this normal or is it likely to be gearbox oil?
Also guessing a new clutch kit will be needed but for the seals to be done does it require the crank to come out?
I said i'd reckon the work would be about £400 plus bits from a decent garage.
Anyone any experience with these?
spider
x 77
Unread post by spider »
The leak will probably be rear crank seal (if its engine oil) or input shaft seal (if its gearbox oil)
The rear crank seal, I cannot recall ever changing one on a TU.D unit, should not be too difficult though: Clutch off, flywheel off and replace seal
Andy.
x 94
Unread post by citronut »
i have got a brand new TUD5 lump stashed away under some racking behind my waste oil container, as it happens i have just had my waste oil removed and will possibly be moveing it all arouns on sunday,
so i will either have a look for you or maybe your freind would like to buy the engine as a spare :lol: ,
im not asking dealer price of around 3K
regards malcolm
spider
x 77
citronut wrote:im not asking dealer price of around 3K
regards malcolm
:o Is that how much the dealer's want to charge for a bare TUD ? :o
Andy.
x 94
it was at the time i bought this one from ebay
regards malcolm
KP
x 27
Unread post by KP »
Well i actually think its now gearbox oil and the place have quoted the fella a fortune to get it through its MOT as it also needs a lower ball joint.
I think he is wanting to scrap it and not bother with it so may buy it cheap and weigh it in myself at a local place or fleabay it...
x 1463
If you're feeling rich..... :lol:
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT
00000139Y8 S/E DIES ENGINE 1,889.05 GBP 2,219.63 GBP 2,219.63 GBP
000001357H DIES ENGINE NEW 2,878.34 GBP 3,382.05 GBP 3,382.05 GBP
Bet they haven't sold many!
KP
x 27
Unread post by KP »
I think its a gearbox fault tbh.
Engine sounds sweet as a nut as well.
if anyone wants it let me know :D
