Xsara Picasso retracting brake caliper piston
JamesQB
x 5
Unread post by JamesQB »
**edited bit about piston in last post**
I want to change the rear brake discs on the mother-in-law's Xsara Picasso 1.6HDi since we're using it while the C3 rests in peace for the time being, and this Picasso is grinding pad backing against disc...
Does anyone have a haynes for it and could enlighten me to any relevant torque values and special actions to carry out, etc when changing pads and discs please?
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
x 94
Unread post by citronut »
i dont have tourque settings to hand, but you must wind the rear calliper pistons back in, and not just lever them, othere wise you will damage the hand brake mechanisum/s inside the callipers,
also i dont know if the picasso suffers with the XANT/C5 syndrom of thick corosion build up between the calliper and rear arms, might best to check whilst your in there
regards malcolm
JamesQB
x 5
Thanks for the advice, I'll check for any corrosion.
New discs have arrived and I see there are just two screws that hold the disc on before the wheel nuts hold it together properly, so I'll just do them nice and tight.
Does it matter which direction I use when winding the pistons back in? With the Xantia I never bothered with direction, just wound them in.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
I would think the Xsara Picasso is the same as the Xsara hatchback. In which case the pistons turn in clockwise. Personally I don't see any reason to do up the two disc screws up very tight. Make sure the mating surfaces are clean and the wheel bolts will do the rest. Caliper bolts go up to 89lbs/ft.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
spider
x 77
Unread post by spider »
The screws are to just hold the discs to the hub, the wheel bolts actually hold them in place properly.
Andy.
JamesQB
x 5
I've tried changing the pads and discs on rear wheels of Picasso and have given up for now after finally managing to do one...
I remembered a C3 forum post where it said cars with ABS must have the bleed nipple opened when retracting the caliper piston otherwise the brake fluid has nowhere to go. After opening the bleed nipple on the first caliper and turning with needle-nose pliers, it went back in very slowly (and hard to turn).
Spent hours on the other rear caliper even using length of wood behind sliding caliper to stop it popping off its posts with the forward force I was applying, but it still just turned and turned (much harder to turn than the other) without going back in!
Is there a secret I don't know about?!
