Xantia alarm and central locking problem
hamster
Unread post by hamster »
My alarm has started to go off at random times for no apparent reason. It went off at 1.30am this morning which was really popular!
Also sometimes when i lock the car and dead lock it the boot doesn't lock but if i unlock and lock again it works fine.
Any idea on either of these problems?
Last year i disconnected the closing sensor for the boot lid as its mounting had broken and therefore it didn't always sense that the boot had shut properly so set the alarm off or wouldn't let it set at all so that kind or rules out the two problems being linked as far as i can work out
Xantia V reg (99) 1.8i 16v lx estate (green)
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Take a close look at the latch on the boot lock, the hinge pin may be worn causing the microswitch not to operate, I had the same problem on my estate.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
You can temperally sort the Siren out on S2 cars...
When you exit the car, with the door open, press and hold the "Siren Mute" button on the dash, the one with the Siren with cross through it, after a few seconds the RED LED on the door by the ultra sonic sensor will stay a solid red...
Close the door and lock the car, this disables the Alarm siren so you do not wake the neighbours up untill you find and fix the problem...
Paul
A very sad...
1994 XM 2.1 d auto
x 8470
These strangely bizarre S2 Cars :roll:
I thought that button did the same as in a MK1 and disabled the ultrasonics but that's a better idea really.
How, in a S2, do you disable the ultrasonics then?
citroenxm
Fallen Hero
x 70
Sorry, I didn't clear that very well...
That button does that at the same time... :oops:
On an S2 when you connect the battery up, theres NO need to rush and cancel the alarm like you do on a S1 car...
Paul
A very sad...
1994 XM 2.1 d auto
x 8470
Excellent Paul,
Thanks for the clarification :D
As a potential S2 owner soon I wished to know how to disable the hooter as I never set alarms for neighbourliness reasons (Note to potential theives: Our locality is guarded 24 hours a day by killer penguins).
The prospect of an S2 that sets its alarm by default every time it locks was causing me a little disquiet...
Tha's put my mind at rest now...
MikeT
x 232
Unread post by MikeT »
According to my recall of the manual (I can't verify it as my alarm doesn't respond) you defeat the ultrasonics with the ignition on, the siren with ignition off.
DickieG
x 33
If the alarm works correctly just set it or if you want to turn it off completely on a S2 use a Lexia, try doing that on a late S1 :wink:
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Xaccers
x 188
Unread post by Xaccers »
If I don't want the alarm going off, I just dead lock the car with the key.
DIY sphere tool
DickieG
x 33
Xac wrote:If I don't want the alarm going off, I just dead lock the car with the key.
The same applies to a S2.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Xaccers
x 188
Juliet's in that position as she's set off her siren a couple of times while sat on the drive.
Don't want to upset the neighbours :)
DIY sphere tool
DickieG
x 33
Xac wrote:Juliet's in that position as she's set off her siren a couple of times while sat on the drive.
Thankfully being a S2 the alarm ECU records the last 15 causes of what triggered the alarm, this is accessed via a Lexia, I'm not entirely sure of this but IIRC using a Lexia on an S2 you can permanently turn off just the siren or how its triggered i.e. sensors but don't hold me to that.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Xaccers
x 188
Richard you're a star! :)
Will have to check next time Jim's free for a lexia session
DIY sphere tool
Gregg1100
x 5
Unread post by Gregg1100 »
Re- the alarm bit. When I first had this S2 car, the alarm gave some trouble. I removed fuse F17 I think it was- no more trouble and neighbours aren't disturbed.
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
x 8470
Excellent stuff Richard and Greg :D
Xac wrote: Will have to check next time Jim's free for a lexia session
The appointment book is open :wink:
Me and Lexia will be at CXM all weekend and at Stratford next...
