Xsara Luggage Compartment Light - Failure
phil.s
....checked the bulb and it's Ok. There's no power getting to it. Do you know where the switch is? It's a 2001 multiplex Hdi. Thanks in advance.
spider
- x 77
phil.s
ACTIVE8
- x 6
If it has a switch like an Xantia, it will be fluid inside a small white plastic device fitted in the tailgate, this fluid moves into the correct position when the tailgate is open to complete the circuit.spider wrote:If you cannot see any switch (assuming its not clever and done of the latch) , do not overlook something like a reed switch (tilt switch) fitted inside the tailgate.
I found this had stopped working on my Activa, and replaced it.
Note it has to be fitted in the correct position for the fluid to work, and conduct.
So when the car is older, and the tailgate has been opened, and closed many times over many years, then sometimes it will move, and then not function.
ACTIVA
phil.s
