Do Xantia's have a brake pad wear light ?
Xantia2.0
Unread post by Xantia2.0 »
The car is a 1998 Citroén Xantia 2.0 EXCLUSIVE. Does it have a brake pad light ? So when the pads get worn it will alert me to get them changed. As there is a soft rubbing sound coming from the front wheels when I brake (due to worn pads I suspect).
1998 Citroen Xantia 2.0 16V I4 with 148,200 miles on the clock. Bought it with 123,000.
andmcit
x 30
Unread post by andmcit »
Yes, there IS supposed to be a wear sensor feed to trigger a dash mounted
warning light but these feed cables do tend to get severed more likely by wear
and tear rather than poor early years workshop maintenance.
Sounds like the pads have indeed had it!
Andrew
Citroenmad
x 110
Unread post by Citroenmad »
Yes, but as Andrew says, they are not to be relied upon. They often break away from the pad or the wire gets cut/worn through, some cheaper pads dont come with wires and often people leave them out.
So its always best taking the wheels off and inspecting them yourself.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
addo
Sara Watson's Stalker
x 95
Unread post by addo »
They are an easy car to change pads on, discs not so much.
At the back you only need a couple of screwdrivers and 10mm (?) spanners. To replace the front you need a caliper rewind tool and some pliers or multigrips.
Note the bleeders should be released just when you're retracting the pistons, then nipped up. One clever bloke worked out the vent pipe on the hydraulic fluid reservoir fits the bleeder nipples, so you can neatly catch the fluid in a jar as it's pushed out.
Homer
x 16
Unread post by Homer »
addo wrote:To replace the front you need a caliper rewind tool
A dowhat?
You mean two big screwdrivers? :wink:
addo
x 95
For Pete's sake, spend the small sum on a rewind tool. :lol: Faster, easier, more satisfying.
Both fronts on my S2 are RH thread - contradicts what others have said...
x 1346
Unread post by xantia_v6 »
addo wrote: Both fronts on my S2 are RH thread - contradicts what others have said...
My Mk1 2.0 and 3.0 have had RH thread on both sides also
Xaccers
x 185
Unread post by Xaccers »
A dowhat?
I normally use the remains of the old pad :D
All Xantia front pistons screw back in clockwise.
The rears just push in.
DIY sphere tool
andmcit
x 30
Yep, all the Xantiae and Xm's I've worked on wind the piston in clockwise
using the caliper tool - are you guys saying you don't want to spend £20
to make life easier? :-s
http://www.tooled-up.com/Product.asp?PID=28819
Andrew
Xantia2.0
andmcit wrote:Yes, there IS supposed to be a wear sensor feed to trigger a dash mounted
Andrew
Well you are proved wrong!!
The light came on today! :)
Xaccers
x 185
Andrew
Surely that proves Andrew right?
DIY sphere tool
ACTIVE8
x 6
Unread post by ACTIVE8 »
andmcit wrote:Yep, all the Xantiae and Xm's I've worked on wind the piston in clockwise
Andrew
Having previously done it without the tool, and then later with it.
I would rather use the tool, than have a long slow wind up, and you can use it other vehicles too.
Also within a short period of time it has paid for itself with the speed, and convienience.
ACTIVA
Xantia2.0
Andrew
No 'cos he said it probably wouldn't work :lol:
Xaccers
x 185
Xantia2.0 wrote:
Xac wrote:
Xantia2.0 wrote:Well you are proved wrong!!
He said the feed cables do tend to get severed, which they do, he didn't say that your cables would be severed.
He also said that it sounds like your pads have had it and need changing, and your light has come on, suggesting that your pads have worn down and need changing.
DIY sphere tool
Xantia2.0
Yeah Yeah, OK!
