95 clio sunroof
the grange
95 clio sunroof
Unread post by the grange »
my eldests clio has a sunroof that seems to let water in, it dose not come in through the roof but through the handle that open it . is there any one that knows how to fix this problem
jason
C3 1.6 exclusive
AX 1.1
SAXO1.4
XANTIA 1.9 TD
BX 1.7 TD
BX 1.9 GTI
antz
Re: 95 clio sunroof
Unread post by antz »
the grange wrote:my eldests clio has a sunroof that seems to let water in, it dose not come in through the roof but through the handle that open it . is there any one that knows how to fix this problem
is it the wind back sunroof if so it could be the antena above it leaking. hope this helps . antz..
amjake
Unread post by amjake »
My daugters sunroof leaked Clio 1996, she said water came in from handle etc.
Did have a problem with the remote sensor last winter, took out dried, wrapped in cling film (garage advice) no longer a problem opening with central locking.
However, I digress, last weekend I pulled out the sunroof rubber seal, got wifey to scrub and degunge (she's good at that :D ) then sprayed with silicone spray and refitted. In all that heavy rain last week not a drop came through the sunroof or handle so I'd say job done!
If not I'll use the waterproof duck tape for the winter seal up, again!
Hope this is of help
Kevin
